replace gauge lights, questions regarding gauge cluster removal
Old May 7, 2007 | 06:51 PM
87350IROC's Avatar
Car: 87' IROC
Hey guys,
1987 IROC
I understand the speedo cable has to be removed in order to remove the gauge cluster. Its not easy to get to the release button. I will have to get a screwdriver up there to hit the button. The question is, it seems like it will be much harder to get the speedo cable back on, since I can't get my hand up there. Is this true?
Is the speedo cable just hanging there, requireing my hand to get it reattached?
Or is it connected to a bracket so I just have to push the cluster towards the front of the car and everything will clip in?
John
Old May 8, 2007 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: replace gauge lights, questions regarding gauge cluster removal
Originally Posted by 87350IROC
Is the speedo cable just hanging there, requireing my hand to get it reattached? Or is it connected to a bracket so I just have to push the cluster towards the front of the car and everything will clip in?
It's just hanging. I find the cable where it enters the cabin and trace it forward as far as I can, line it up, then push the cluster forward while I hold the cable.
JamesC
Old May 8, 2007 | 09:18 AM
87350IROC's Avatar
Car: 87' IROC
When i was under the dash, I had a heck of a time getting my hand behind the dash, my speedo cable had vitually no play in it. I could only pull out the cluster maybe 1/4 inch with the cable attached. If I lower the steering column via the two bolts, will it be easier for me to get my hand back there?
Old May 8, 2007 | 09:49 AM
JamesC's Avatar
No (though getting the cluster in and out will be easier).
JamesC
Old May 8, 2007 | 01:35 PM
87350IROC's Avatar
Car: 87' IROC
Ok thanks for the help. This job doesn't look like fun. I don't think my back will like it.
Old May 9, 2007 | 09:55 PM
87350IROC's Avatar
Car: 87' IROC
I ended up releasing the speedo cable with a long screwdriver, not a big deal. Suprisingly, I was able to get the cable reconnected very easily. I couldn't get my hand up there, but I just pushed in on with a long screwdriver.
JamesC thanks for the help.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
