Help
Old May 8, 2007 | 06:29 PM
taurus2210's Avatar
Car: 879 fire bird formula
Engine: 305 i think
Transmission: not sure
Help
Hello i have a 87 firebird 305 carborated.anyway the problem i have is i instaled a tail light switch at the brake pedal. and now for some reason every time u press the brake the dash lights and the parking lights come on
any help would be grateful
Old May 10, 2007 | 05:38 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: Help
What caused you to replace the switch? Sounds like you got a bad bulb or socket in the brake lights - brake light filament or wire laying on parking light filament or wire. Step on the brakes and power is fed back into the parking light circuit. Check brake light bulbs first.
Corky
Old May 10, 2007 | 05:53 PM
taurus2210's Avatar
Engine: 305 i think
Re: Help
what caused me to replace the switch is that the brake lights went out complety. i checked the bulbs and they were fine i have brake lights but when i turn on the lights u can't see the brake lights come on
Old May 10, 2007 | 07:39 PM
Corky's Avatar
Engine: 2.8L
Re: Help
Let me see if I got this right - you have brake lights with the parking lights off - when you turn parking lights on, you lose brake lights. Is that correct?
If so,
Sounds like you are losing a ground back there. Run a temp ground wire for the brake lights and see what happens. Can't recall if the lights share a ground, but check all grounds back there.
Corky
