Air/Fuel gauge on a non-o2 car?
Old May 9, 2007 | 07:59 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Does anyone have a air fuel gauge hooked up to a older non-O2 equipped car? Do I have to add a 02 sensor?
Old May 10, 2007 | 02:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Air/Fuel gauge on a non-o2 car?
Yes, the air/fuel gauge reads the signal from an O2 sensor to make it work.
Old Nov 21, 2009 | 03:20 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
sorry to jack your post, but if youve got a car with o2 already, can you run another o2 sensor just for the gauge? like adding a wideband sensor without running it to anything but the gauge?
Old Nov 22, 2009 | 05:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you install another bung in the exh for the 2nd sensor
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
