speedo wire
Old May 9, 2007 | 08:20 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
speedo wire
Ok i have a 91 formula 700r4, with a carbed sbc. my question is which wire from the tranny(color) is supposed to go for the speedo. i cut back most of the wire harness that i didn't need, but as of now i have a blue,yellow, purple and green wire hanging off the tranny. which do i hook back up to the speedo?
Old May 10, 2007 | 08:36 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: speedo wire
Purple and yellow. The purple is the ground. Yellow is considered the signal wire. But you CANNOT hook it up directly to the instrument cluster. THe signal needs to be converted (from 0-12V pulses to a gnd trigger) by either the ECM of the yellow buffer box that used to be on 'birds before 1990.
Hope this helps.
Lou
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
GTAman
Aug 27, 2015 10:29 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
