What is wrong with my high beams?
Old May 10, 2007 | 05:45 PM
5150RS's Avatar
Car: 92 RS Camaro
Engine: V6
Transmission: Automatic
Hey guys, I need some help. My high beams always worked just fine, but one day they just stopped working. When I pull the turn signal back it does not click into place anymore. So do you guys know if the whole turn signal needs to be replaced or what?
Old May 11, 2007 | 04:54 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
Re: What is wrong with my high beams?
Sounds like maybe the rod is off either on the signal bar or possibly down at the switch. Does the signal bar feel loose or is the tension the same while they were working?
Old May 11, 2007 | 07:19 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
tilt column loose?
Old May 11, 2007 | 10:35 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
A common problem is that the hi/lo beam switch gets loose and no amount of pulling on the turn signal stalk can switch the beams.
The turn signal stalk merely pushes on a metal rod that follows the steering column to the hi/lo beam switch that's attached to the steering column under the dash. Usually, it just takes 10 minutes to readjust the switch and then it works fine again.
Actaully we have a write-up on the this issue on our ATGO page, right here: http://www.austinthirdgen.org/module...howpage&pid=18
Hope this helps.
Lou
Old May 11, 2007 | 04:23 PM
Spiers's Avatar
Yes it's easy to fix, I had the same problem. Look under your dash and pull back the high beam lever... you will see a white plastic deal there. You have to loosen the two screws that hold it on the steering column, adjust it, and tighten them back down. It shouldn't take too long depending on how big your hands are
Old May 11, 2007 | 05:11 PM
naf's Avatar
naf
I would only use the adjustment procedures described above if the steering column is still tight. A loose column can cause it to come out of adjustment but re-adjusting it at the switch doesn't fix the loose tilt.
If the tilt is tight, go for it.
Old May 12, 2007 | 12:11 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I have the same problem. But when the column is dropped they work like a champ. But as soon as you bolt it back up the lever will get really hard to pull. I can pull the lever once then it stops. Adam :-)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
WickedBowtie
Sep 11, 2015 11:24 PM
