voltage regulator
Old May 10, 2007 | 11:03 PM
haxmire's Avatar
Car: 1987 350 swap
voltage regulator
I have recently been having electrical problems. The alternator is brand new, and the battery is good. The car will crank right up.
The problem I am having is that the voltage gauge moves up and down when i have my blinker on. Also when I turn my lights on it moves down then back up. After about 5 mins of driving the volts start to lower and eventually get close to 8 volts. Well if I wait a little while and then crank the car back up the volts are back up but the same thing happens again.
I told this problem to a friend of mine and he said voltage regulator. Is there anyway to tell if this is bad, or will I have to buy a new one and install it and see if it works? If so, how hard is it to install a new one and where is it located to be replaced.
Old May 11, 2007 | 06:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ADVICE FOR NO CHARGE
First you need to make sure the voltmeter
on the dash is correct.
The only correct way to monitor bat voltage is to connect
a meter directly to the bat.
You can compare your dash voltmeter
to a voltmeter connected to your bat
to see if they match.
Your regulator is inside the alternator.
Because your alternator is new it is under warrantee.
Therefore you can get a new alt at no cost.
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
