what size wrench /oil press. switch?
Old May 12, 2007 | 07:26 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i (like an idiot) put sealant on the threads finger tightened it as hard as i could,now it 's not in far enough to be out of my headers.i've tried every tool i have nothing seems to fit.i realize i should of test fit it first.i don't have much room because of the headers ,but i don't want to take the header off because they are welded to the straight pipe. thanks for reading.
Old May 12, 2007 | 09:03 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Re: what size wrench /oil press. switch?
Do you have a pair of channel-lock pliers? They are adjustable and should be able to fit around the switch. Get a good firm grip and turn very carefully so as not to break the contact on top or strip the threads. Take your time and it should be ok as long as you get it screwed in far enough to prevent an oil leak (bad personal experience, lol).
Old May 12, 2007 | 09:27 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i'll try that,i just went and bought a 15.00 socket just for oil unit, theres not enuff room for it to fit.
Old May 13, 2007 | 09:23 AM
elky74's Avatar
Did you get 'er?
Old May 14, 2007 | 05:57 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no i didn't,but im going this morning to see if they will exchange the socket for a wrench.i did figure out its a 1 -1/16 .what a crazy size.
Old May 14, 2007 | 08:00 AM
elky74's Avatar
Sounds like you're on the right track now, good luck.
Old May 15, 2007 | 06:29 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yep, the open end wrench worked ,but it was 5 dollars more.at least i got it .thanks 4 your time.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Dkelz313
Apr 7, 2016 10:38 PM
toronto formula
Nov 10, 2015 06:17 AM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
knight72
Aug 10, 2015 09:32 PM
