starter wiring
Old May 14, 2007 | 05:23 PM
91 VANE Z's Avatar
Car: 91 Z28 Convertible
starter wiring
Hey guys. I bought a mini high torque starter, threw it in my car, 91 5L TPI.
Now every time I turn the key forward and the car starts, for about 1 second, It makes that annoying sound starters make when you try to start your car but its already on. A friend told me It's wired wrong and that the starter is probably on all the time. I wired the new started just like the stock one was. All the big wires on the big post and the single purple wire on another post by itself.
Does this make sense?
Thank you in advance.
Old May 15, 2007 | 03:11 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Re: starter wiring
Nope, you got it wired right. Sounds like the starter needs a shim!
Old May 15, 2007 | 07:42 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Re: starter wiring
i had this problem too, it turned out to be that my key kept getting stuck up in the start position, and that kept the starter going the whole time.... dunno if that helps any...
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
