opposite headlight rotation
Old May 12, 2007 | 02:45 PM
mathlic's Avatar
hey there
i have an 88 firebird formula.
i have a 3 wired driver head light motor and a 2 wired headlight motor on the passenger side.
is it possible to have them workin in sync?
b.c they both rotate opposite. when one goes up, the other goes down. vice versa.
what should i do?
~Matt
856-340-5080
Old May 12, 2007 | 09:41 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: opposite headlight rotation
The wiring is different on older models. As you need the relays to swap in the newer ones to a older car. I image that is you problem. Install a proper one.
Old May 12, 2007 | 11:28 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Both of your motors should be two wire. I am fairly certain you have an incorrect motor. The earlier models used three wire motors when they had individual relays. The cars with the firewall mounted module have two wire motors. 87 was the first year for the two wire setup.
Pac J
May 17, 2020 10:44 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
