Car doesn't want to idle
Old May 13, 2007 | 06:15 PM
Jb87IROC's Avatar
Well, I've been working on this issue since I bought my 87 IROC last week. I hooked up a code reader and returned a code 36...bad mass flow sensor. I drove over to advance just to swap one in and see for myself. No change in my situation, and still throwing a code 36.
Next, I took the IAC out and cleaned real good. I also opened the air adjustment screw abit. I am either stuck with the car wanting to take off in drive or sputtering and sometimes dieing. Car dies right around 500 rpm.
Engine runs great and shifts smoothly once moving. I'm thinking I have a wiring issue? I doubt that the other MAF I tried was bad.
Old May 13, 2007 | 11:41 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Car doesn't want to idle
Do you have an ALDL cable? It might be interesting to datalog and see exactly what data the ecm is getting for your maf.
Old May 15, 2007 | 06:20 PM
IROC 86's Avatar
my 86 iroc has a power source right up near the fuel pump by the break boster on the driver side of the car. relay start their and see if you are getting power to the MAF.
Old May 15, 2007 | 07:02 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
A little more info on code 36 - a new MAF aint gonna fix the problem below. IROC 86 above may be spot on with your problem. Unfortunately, I don't have a wiring diagram for the relay.
Corky
36MAF sensor burn-off voltage was missing. Check MAF sensor burn-off relay and terminal "D" on MAF.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
