HELP......Electric Hatch
Old May 15, 2007 | 07:37 PM
kidcope's Avatar
Car: 1988 IROC Z
I just recently had my electric hatch stop working and it is still popped open. I can't get it to take and close so I can't take it anywhere to get it fixed or get anything. What do I do? HELP!! PLEASE!!
Old May 15, 2007 | 08:14 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Re: HELP......Electric Hatch
Well first off is that I myself have this problem too...and for the time being before you can fix it...just slam the hatch down and it should stay down and not swing open at all...now it wont be completley air tight but its fine to get around.
my hatch has been like that for awhile now
Old May 15, 2007 | 08:25 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check the tech article on the TDS site on the sidebar of this page. It will give you the info and parts required to get your hatch working again.
Old May 27, 2007 | 09:21 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
when you open the door to your car does the lights turn on?... If not check your fuse... Cuz it happend to me also cept mine latched then sometime blew the fuse... then tried putting the t-tops back there.. hit the open switch and nothing.... Then my sister said that the int lights stopped working about the same time the hatch stopped. Checked my fuse and it was bad. replaced it and bam it opens.
Old Jun 7, 2007 | 08:10 PM
kidcope's Avatar
Car: 1988 IROC Z
ya I still get the light on and It clicks when I try to release it. I don't know it it makes a difference but it seems like the hatch has moved pretty far away from the rear end of the car. Like it has slid down quite a bit.
Old Jun 10, 2007 | 11:52 PM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
Has the pull down retracted? On my Bird, if I don't put enough pressure on the hatch when I shut it, the pull down will go down and not latch on to the hatch at all. Trying to pop it doesn't work, it stays down. Like 86FireBird, I have to slam the hatch to get it to take properly. I know there is a "right" way to do this, but I have had good luck in praying that the glass won't break when I slam the hatch down.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
