whres no.1 on the dist cap?
Old May 18, 2007 | 05:52 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i tore this car apart ,now i'm putting it back together.the problem is i didn't mark no .1 on the distributor cap.does anyone know which one it is ?
Old May 18, 2007 | 08:43 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: whres no.1 on the dist cap?
anywhere you want it to be.
wherever you start #1 just follow the firing order around the cap. everyone usually starts #1 by the hei and tach plug in and faces it towards the #1 cylinder. firing order is 18436572 just point the rotor at #1 when #1 cylinder is at tdc compression stroke and you will be good to go. static time your motor to 6 to 10 degrees on the timing tab. drop in the distributor pointed at 1 on the cap wherever you decided to put it..
sheachopper
Jul 31, 2019 11:27 AM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Damon
Sep 26, 2015 04:29 PM
