whats this sensors name?
Old May 20, 2007 | 02:31 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
what is the sensor called that goes into my passenger side head ,its in the back and screws in right under header between the last two tubes of my header.mine is gone.
Old May 20, 2007 | 05:32 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: whats this sensors name?
should be a temp switch for the fan
Old May 22, 2007 | 06:53 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i'll run down to advance auto and buy one.hopefully that is it.
Old May 22, 2007 | 10:32 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
If my temp guage shows no temp what sensor would I need?
I am replacing all sensors just want to know which one does this.
Old May 22, 2007 | 02:02 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, i went down to the store today .and every switch they showed me wasn't it. i'm gonna try a junkyard.
Old May 22, 2007 | 02:27 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Whats the difference between your temp sensor (driver side of block) and coolant sensor (front of manifold)?
P.S. Let me know all locations of sensors....I am replacing all of mine and only know of Coolant sensor ( Front Of Manifold ), Temp sensor ( Drive Side Of Block ), Knock sensor ( Passenger Side Of Block ), O2 sensor ( Exhaust ).
Old May 22, 2007 | 02:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The driver side head has the coolant temperature gauge sender. The passenger side head has the auxiliary fan switch. The manifold has the coolant temperature sensor for the ECM.
Old May 22, 2007 | 03:47 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Cant find that one? Is it by the knock sensor...as I have to connect that back up too.
Old May 22, 2007 | 03:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's in the head. If you have a single electric fan, you might not have one.
Old May 22, 2007 | 03:57 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I only have a single fan...so maybe thats why.
Old Sep 23, 2007 | 04:05 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
I have a single fan and i have one ^^ i just cant figure out how to get it off, cuz there is a damn heat sheild in the way :/
Old Sep 23, 2007 | 04:24 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I Hear that !!! That fan temp sensor is in the WORST place !!!
You can't see it and it's even harder to reach if it needs to be replaced.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
