flickering lights?
Old Jun 1, 2007 | 09:47 AM
Vincez28's Avatar
Car: White 1985 z28
Engine: 305 4b carb
flickering lights?
hello all, just got the car back on the road. a bought a new battery and put it in. so i know the battery isn't the problem. so here is what's happening. with the car off, when i open my door or pull out the lights everything if fine no flickering of lights, but when the car is ON and open the door the dome flicker as well as at night when i turn on my lights(dash lights)everything flickers with the stereo OFF? what could be the problem? engine grounds loose, if so where are the location of the grounds?, alternator issues.......if alternator issue can i check it with a voltmeter?
thanks,
Vince
Old Jun 1, 2007 | 08:40 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: flickering lights?
Hey i too have that same problem... my dad told me that it was a ground wire loose but im looking for other answers too....
Old Jun 1, 2007 | 09:12 PM
Vincez28's Avatar
Car: White 1985 z28
Engine: 305 4b carb
hey, someone told me about the grounds being the main reason, but why would't the lights flicker with the car off? the lights r still be grounding. maybe there is a loose ground somewhere. i wonder how many grounds there are in the car and where the locations r?
Old Jun 1, 2007 | 09:15 PM
19CAMARO85's Avatar
Im not really sure... i figure that the lights dont flicker until the cars started because the idle vibrates them slightly loose due to the emgine movement... I will try to find out where the grounds are. If i find it ill let ya kno. Mabye someone else will have other ideas or info
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
