Push button start?
Old Jun 6, 2007 | 02:18 PM
Darkhorse's Avatar
Push button start?
My '85 camaro wont start. I was told this is due to the gears, of the key switch, being worn off at the bottom of the steering colomn. Instead of replacing them I want to make it push botton start, like a race car would have. How do I do this? I will still use the key to lock my steering wheel.
Old Jun 6, 2007 | 02:28 PM
Re: Push button start?
I was told
That's a good one.... I've heard some real whoppers, but I guess they make up new ones every day.
More likely, you just need to adjust the ignition switch; or worst-case, replace it. You can get a new one at any parts store for about $15.
Old Jun 6, 2007 | 03:54 PM
Darkhorse's Avatar
I tried that. It didnt work. The guy that told me was in the parts store, a customer. He had nothing to gain by giving me this info.
Old Jun 8, 2007 | 04:31 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I would try looking at a few other things,such as the wiring to the starter,the neutral safety switch as well.There are a number of things that will cause that problem.As sofakingdom said,also try adjusting the ignition switch,there is a acuating rod that is moved when you turn the key,maybe thats all it is.Good luck with it.
Alicat.
Old Jun 8, 2007 | 09:21 PM
Darkhorse's Avatar
So nobody knows how to wire this like I asked?
Old Jun 8, 2007 | 11:19 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
yes, I do. but WHY when you can fix it the ight way for less $.
#1 your gonna need a Good heady Duty Starter Button.
A Honda S2000 one is nice $39-90 depends on where you get it.
Then a typical 40/50A relay
Do a Google search you will find what you need from there.
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
smooth
Aug 18, 2015 06:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
