code 36 unanswered questions
Old Jun 15, 2007 | 12:39 AM
seymourless's Avatar
hey
so ive just spent like 3 hours carefully reading all the code 36 and related posts, and i need to see a picture of this so called glowing red wire. i dont see anything capable of glowing like that in mine, and have yet to ever see it glow. also, the ses light also comes on when i drive on the highway for about 20 mins, with the same code popping up. sometimes it goes away by itself also when doing that. i replaced my maf sensor like 6 months ago, but have also pointed out just now that i can hear my fuel pump running for about 2-3 seconds after i shut down my car. My car will initiate the code right after it bogs down kind of under hard acceleration. And my last question, what makes the car run like crap when the light is on? (by crap i mean not as good acceleration) is it the burn off in the maf that is making it mess up, or is it the computer telling it not to be a nice car to drive? lol
any help would be awesome!
thanks.
P.S. i just remembered i bought some maf cleaner the other day, and after using it the car ran phenomenal for like a day, AWESOME acceleration. only to return to ses light acceleration the day after tho
Old Jun 16, 2007 | 11:38 PM
Re: code 36 unanswered questions
also every time i start up it smokes really bad for like a second or 2 then goes to normal. again any help would be greatly appreciated about this stupid burnoff junk. thanks
Old Jun 24, 2007 | 12:28 AM
larry m broom's Avatar
Car: 1986 trans-am
Engine: lb9 slow 5
Transmission: slushbox
Axle/Gears: 3.42, 10 bolt from 95 camaro
i dont think youl ever be able to see it i think it only kicks on while driving.
the glowing red wire is the wire that goes across the litle terminals in the maf itself when enine is running look through the maf and may see it.
the smoke depends on what color it is when start up if its like a blue color its your valve guide seals in your cylender head laking oil on the pistons while engine is off. what your seeing is oil being burned up.
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
