wire primary and secondary fans together
Old Jun 20, 2007 | 09:21 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
How can i wire my fans so that both fans come on when the thermal switch reaches a certain temp?
Old Jun 20, 2007 | 10:19 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: wire primary and secondary fans together
Over on the right side down next to the frame rail you'll see the high pressure AC tubing with a pressure switch on it. This turns on both fans with the AC high side pressure gets to a certain point. Tap into these two wires and you can control both fans through the factory relays.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
