VSS connection for a 305 TPI / th400 combo?
Old Jun 21, 2007 | 04:29 PM
ak47's Avatar
I have a 305 TPI from an '86 T/A that I've put in a 85 pickup. I left the turbo 400 transmission in the the truck and I'm not sure what I need to do to get the vehicle speed sensor (VSS) hooked up. At first I thought I wouldn't need it, but after some research I found that it sends a signal back to the ECM which is needed for the engine to run at peak performance. Any ideas? I'm not sure where to start with it.
Thanks.
Old Jun 22, 2007 | 06:58 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: VSS connection for a 305 TPI / th400 combo?
http://hp.autometer.com/products/acc...do_sender.html
This might be a product worth taking a look into? Click on the model number to the right.
Old Jul 15, 2007 | 09:10 AM
ak47's Avatar
I finally found a VSS that worked for my application, I got it from jagsthatrun.com, it is an adapter type that installs where the speedo cable would go, then the cable plugs into this sensor. Works great!
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
