Eurolite H4 Headlamps....WITHOUT APC HARNESS
Old Jun 22, 2007 | 10:06 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I like only having 2 headlights....the outer headlamps. I found this site that has a 2 headlamp harness unlike APC's required 4 headlamps.
I want to get rid of my 2 inner lights so I can have extra ram air.
Here is the harness
http://www.2kracing.com/product_info...oducts_id/1358
So H4 with both high and low beam with 2 headlamps and this harness will keep my Bright lights and low lights...what do you guys think.
That and to shave off some weight on the front of the car.
-H8 That Torque-Steer
Old Jun 22, 2007 | 02:42 PM
Stephen's Avatar
Car: 87 GTA
Re: Eurolite H4 Headlamps....WITHOUT APC HARNESS
If you delete 2 of the lights, how are you going to handle the low/high beams, as 2 are lows, 2 are highs. IIRC, the inners are the highs, outers lows. You'd have only lows. If you only drive in the city, when there is traffic, there is really no need for highs anyways. I rarely use my highs. I wouldn't miss them if they were gone.
But, since Pontiacs have dual low/high headlights, I only have 2 anyways.
Old Jun 22, 2007 | 03:37 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Lol. H4 bulbs are dual filament....meaning both high beams and low beams...I was just wondering and letting everyone know about this harness for those who want to delete 2 lights and still be able to use the H4's
But yes....H4 bulbs are dual filament. Which is what I will be getting. Some 4100K 55watt low beams and 90watt high beams super plasma white bulbs.
Old Jun 22, 2007 | 06:03 PM
Stephen's Avatar
Car: 87 GTA
Ah! Duals for a Camaro would be cool then, and use the other 2 openings, for ONLY the cooler, outside air, for the engine.
tataconka
Apr 5, 2004 10:05 PM
