fuel pump relay and starter
Old Jun 22, 2007 | 11:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a 1986 305 5.0 v8 tpi fuel injected automatic trans am
ive replaced the injectors, distributor cap, rotor, ignition module, wires and plugs
fresh battery
new fuel filter
it has the original fuel pump relay
my question relates to why my car takes a good 3-4 seconds to finally fire up.
like 1.....2.....3.....etc...
i know if the fuel pump relay is bad the oil pressure switch allows you to drive the car
btu what is the real task of teh fuel pump relay like when does it function and wat does it do?
and could the starter be going or just dirty connection?
any ideas?
Old Jun 24, 2007 | 11:13 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: fuel pump relay and starter
The ECU uses the fuel pump relay to control the fuel pump.
Normally, it runs the fuel pump for 2 seconds when you turn the ignition on. That's the prime cycle. Then once the engine starts turning (pulses start coming from the distributor), the ECM turns the fuel pump on again.
So if you turn the ignition on and you don't hear the standard 2-second "whine", you might possibly have a problem in the relay circuit.
Hope this helps.
Lou
Old Jun 24, 2007 | 01:00 PM
Bobby_80s's Avatar
Axle/Gears: no idea
but if the car runs and drives is it possible for the fuel pump relay to be bad and just relying on oil pressure to drive?
Old Jun 25, 2007 | 11:05 AM
BigBadLou's Avatar
Engine: TPI
Definitely.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
