jegs cooling fan relay kit
Old Jun 27, 2007 | 09:54 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Im carbed now and would like to wire the fan that is controlled by the ecm to a jegs cooling fan relay kit. Right now its on a toggle switch. My question is it has 4 wires a pink wire for 12 volt power then another pink wire to go to the positive side on the fan a yellow for the thermal switch and a gray to go to a toggle switch. My question is will i still need a 12 volt power wire to the toggle switch or just the gray wire to one blade on the toggle switch. My other question is should i use a switched or full time 12 volt power source to the new relay?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Leggman1
Aug 6, 2015 04:15 AM
