Trunk latch got broke!
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
Eh... I fixed it
muckin around with the fuse box + wires I guess I did something right cause now it works >.>
Thanks for the suggestions!
muckin around with the fuse box + wires I guess I did something right cause now it works >.>Thanks for the suggestions!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Trunk latch got broke!
can you hear the pull down motor running?
it could be a fuse, something unplugged, the sensing switch, a broken pull down gear, along with a few other things.
what ever it is, tops down probably has the parts you need.
http://www.top-downsolutions.com/pro...roducts_id=107
the plastic guides breaking can cause other damage, so its probably a good ideal to get a set of those too when you find whats wrong.
Transmission: 5spd
Axle/Gears: Unsure
i checked the fuses last night, not all of them though. there isn't exactally one labled "trunk latch" :P
no i dont hear the motor either. i realize it could be alot of things, considering the trunk light doesn't work, and i dont even hear the motor. you would think if it was just all bent up the motor would try to work but couldnt cause it was all effed up right?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
PUT A LID ON IT
"whoever it was at maaco slammed my trunk and broke it"
If it’s in pieces you must repair or replace.
However from your description it sounds like
the “trained professional” caused it to
pull down sans lid.
If it’s in one piece:
On the aft of the main assembly
is an activator
( toggle mechanism ) that can be accessed
with a screwdriver.
Flipping this up will cause the unit to raise
up to meet the door.
"oh it was that way when you brought it here"
"i checked the fuses last night, not all of them though.
there isn't exactally one labled "trunk latch""
There are 2 fuses involved with the pull-down unit.
“LID” ”ACC”
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
Transmission: 5spd
Axle/Gears: Unsure
Re: PUT A LID ON IT
pull down sans lid.
is an activator
with a screwdriver.
“LID” ”ACC”
Happy Racing !
|__|==(_)==|__|
I dont know how the trunk light would be effected though, but ill check the fuses and i called the guy and he said he would try to get it fixed for me. Ill try to find the release mechanism as well ^^ Thread
sjorgens
Oct 1, 2015 07:54 PM
