where can I move knock sensor to?
Old Jul 4, 2007 | 11:23 AM
laidback's Avatar
I posted in TPI but didn't get any responses. Anyone have any suggestions where to move the knock sensor to on a flat tappet block w/ '92 TPI so that I can change to center dump block hugger headers?
thanks
jeff
Old Jul 9, 2007 | 06:36 AM
oldman305's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI, 93 LT1 cam, 081 hds, hdrs.
Transmission: Built - 700R4
Axle/Gears: 3.27 gears from '87 TA w/rear disc
Re: where can I move knock sensor to?
Jeff,
After talking to Howell Industries in Marine City, Michigan about the same thing, they said it could be moved to the frame or the motor mount. This is where they tell the hot rodders to move it when using block hugging headers. They told me, anyplace is OK as long as it has a good ground.
Good Luck, Mike
Old Jul 9, 2007 | 02:22 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Yes, but then it wouldnt work.
It needs a solid acoustic coupling to the motor to detect knock. it also must be away from the valvetrain as much as possible.
Old Jul 9, 2007 | 08:14 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Tap into a coolant vein perhaps. Somewhere away from the valvetrain. Liquids are great transporters of sound, so perhaps mounted in the radiator and exposed to the coolant. That would be better than the frame at least.
EDIT: Maybe in a pressurized oil passage, cause I'm sure that would carry the sound. You may have more valvetrain noise there, though.
Old Jul 12, 2007 | 06:55 PM
laidback's Avatar
I though the same thing about valvetrain noise but what little research I have had time to do it seems there are several later model motors (imports I think) that have the sensor in the head or intake. I figured I would keep it low anyway. One guy said drill and tap the fuel pump block off plate but I wasn't sure if that would transmit the harmonics or how sensitive the sensor is. Another guy said he has done a few and just put a couple 45 degree fittings in stock position to turn it away from the exhaust. Once again I wasn't sure if the brass would transmit the harmonics but it is still in the water jacket. I may try that and see what happens. I just don't want to be chasing my tail if I don't have to.
thanks for the replies
Old Jul 13, 2007 | 08:23 PM
pizza_guy's Avatar
The brass fittings, while not exactly elegant, is probably the best idea for retaining the functional aspect of it. The factory exposed it to the coolant for a reason. I doubt the brass fittings would affect it at all, as long as it's still exposed to coolant.
Old Jul 19, 2007 | 05:29 PM
laidback's Avatar
thanks for the input. Put the 45's on so I'll see how that works, just have a few other mole hills to cross first.
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
willyjoejr
Sep 3, 2015 09:26 AM
