Trans am headlight (weird) problem?
Old Jul 18, 2007 | 07:11 PM
Jammen Firebird's Avatar
Ok well I have a weird problem with my pass. headlight. Well when I first got the car neither headlights would pop up all the way. one would alittle the other one wouldnt then they both would a very little bit. so today I was messing with the front end of my car and had the headlights off of the car when I went to hook the pass. side back up the motor opened the headlight up all the way and it is still like that I didnt even turn the light switch on it just poped up as soon as it was all pluged in . So I tried turning on the light switch on and the light lit up and when I turned it off the light stayed up so I unhooked everything and the light is still up. also i hooked up the driver headlight and it acts just like it did before. PLEASE HELP.
BTW: The car is a 83
Last edited by Jammen Firebird; Jul 18, 2007 at 07:12 PM. Reason: Automerged Doublepost
Old Jul 19, 2007 | 09:14 PM
jstuart83's Avatar
Re: Trans am headlight (weird) problem?
when you turn the light switch do the headlight motors run if so gm used plastic ***** that connect the motor the the actual gear in the motor gear assy. you can replace them with 1/4 nuts. i had to do this on my 87 gta orks ive also done it on my 94 ford ranger
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
The_Phoenix
Feb 4, 2016 07:10 AM
TheJoeY88
Aug 13, 2015 06:51 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
