Headlight motor mystery
Old Jul 4, 2007 | 05:58 PM
Firebirdstu's Avatar
Car: 82 Firebird
Engine: 5.7 400hp Gto 350 block
Transmission: th350
Here in the uk recently we had a bad flood, and my firebird had no choice but to drive through some of the water, since this the headlamps wont go up or down, the only resistance i can feel is when i push the **** on top down or up, since this ive had the motor appart taken the side cover off to access the electric connector block, i tried 12v to each of the 3 contact wires, nothing...
theres a U shaped metal piece inside with 2 connectors on it, once on of the contacts is pushed towards where the + or - contacts are, the motor spins, its really baffling me so any input would be great, all relays seem fine, i would think that a 12v source to the motor would at least make it spin.
Stu
Old Jul 28, 2007 | 06:42 PM
Mike85TALimited's Avatar
Car: 1985 Limited Edition Trans AM
Engine: 305 4BBL LG4
Transmission: 5-Speed Borg Warner, 77MM, 2.95
Axle/Gears: Limited Slip/3.27
Re: Headlight motor mystery
I've had problems like this before too... As long as the motors still work (fight you when you try to manually turn the ****) the trick is to fully remove all components from the motor and put them back in. That's it.
Worked for me atleast...
Old Jul 29, 2007 | 12:33 AM
Car: 82 Firebird
Transmission: th350
found out the problem with this, if anyone else has this trouble its the internal contacts, does anyone know if these can be replaced or is it easier to find another motor?
heres a few pics of it:
cheers
Stu
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
