i have not a clue what this is....
Old Jul 9, 2007 | 05:55 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
first off i changed the cam and intake runners on my 85 tpi. after this i had two problems.
1= the voltage would slowly drop off at idle.
i cleaned up the main ground to the alternator bracket, and i think that fixed it, but at this time i dont have a volt meter to check. but the battery hasnt died yet so thats a good sign.
2= the car idles fine, but if i floor it the rpms stay the same and the car sounds like it on a rev limiter. if i just give it a little gas the motor gives a few more rpms(up to about 3-4k).
the battery and the alternator are new. its getting spark and the fuel pressure is good. i have MSD, i tried it with it hooked up and with the stock ignition.
i dont know if this means anything but i unpluged the maf and the motor reved with no problem what-so-ever.
could the two problems be linked together?? could it be a bad ground?
Old Jul 9, 2007 | 06:37 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Re: i have not a clue what this is....
i just put a new maf power relay on it. no change.
if i slowly creap up on the throttle it will rev clean and as soon as i hear it sputter if i let off just a little it cleans right back up.
Old Jul 9, 2007 | 07:03 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
possible T.P.S. problem?Had that problem with my old 87 IROC,problem solved after I replaced the T.P.S.,the motor was completely stock though,so this may or may not be the problem
RedLeader289
May 28, 2019 01:47 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Jlanz55
Sep 9, 2015 09:09 AM
TheExaminer
Sep 6, 2015 11:40 PM
CORV3TT3
Aug 23, 2015 11:26 AM
