brake and blinker
Old Jul 11, 2007 | 09:26 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
brake and blinker
ok when i hit my brkes my drivers side blinker comes on it dosnt blink it just a a solid light till you let off the brake anyone know how to fix this so it dosnt lite up when i hit the brakes
Old Jul 12, 2007 | 09:49 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: brake and blinker
It would definitely help if you told us what car/year/model you have. The wiring is often different. You can actually fill out your profile and all the car info will then show up under your avatar.
The cause could be as simple as a bad ground or as bad as a malfunctioning turn signal switch.
Lou
Old Jul 12, 2007 | 05:10 PM
Engine: 383 stroker
Transmission: th350
thank i just did my profile and all but if it not showing up its a 1984 trans am 305 carbed
Old Jul 13, 2007 | 08:00 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Possibly a bad ground or most likely a bad socket.
Old Jul 13, 2007 | 10:00 AM
BigBadLou's Avatar
Engine: TPI
What happens when you turn on the blinker and hit the brake?
All bulbs work fine in front/side/rear turn signals?
Lou
Old Jan 15, 2008 | 10:55 PM
Engine: 383 stroker
Transmission: th350
when i turn the signel on and hit the brake it stay lit up tilli let off then it flashes
Old Jan 16, 2008 | 06:04 AM
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Does the other side work properly? If so, you probably have a bad bulb on the side thats not flashing. (Make sure that you check the front, and sometimes the side-front as well) If it's not the bulb, it will be a bad socket, bad ground, or bad wire to the bulb on that side that is not working.
Old Jan 16, 2008 | 11:34 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Sounds like a ground issue. How is the charge in the battery? I've had some weird light issues on vehicles that have been stored and had low batteries.
Old Jan 16, 2008 | 06:10 PM
Engine: 383 stroker
Transmission: th350
its a brand new battery and when i since storage i have un hooked the battery and go out every once in a while and put a low charg on it if it needs
Old Jan 16, 2008 | 07:07 PM
BigBadLou's Avatar
Engine: TPI
I have two thoughs:
1) if the left brake light is dimmer (with the turn signal on - would be more noticeable at night), I would suspect a bad ground behind the driver side tail light
2) if not dimmer, I would suspect the multifunction switch (turn signal switch in the steering column, under the steering wheel)
I sure hope this helps!
Lou
Old Apr 23, 2009 | 10:43 PM
Engine: 383 stroker
Transmission: th350
sorry for the long over due post i still havnt got this fixed im thinking its somewhere under the brake pedle it self cause i just bearly tuch it and the left signel will light up and when i use the turn signle it will plash hit the brakes it will stop flashing go solid and then when i let off the brake it will start flashing agean
Old Apr 24, 2009 | 11:35 AM
ACCLR8N's Avatar
My son's STS did a similiar trick. The bulb socket was bad. Specificaly the ground wire tab had rusted apart. We cut open the plastic a soldered the wire back in. Not worth the effort with the more readily availble (cheaper than Cadilac) third gen replacement sockets.
Old May 1, 2009 | 09:18 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Hmmm ... I'm having a similar problem. Except mine is that the third brake light flashes with the left signal. My left signal won't work when the brake is on.
Old May 1, 2009 | 09:21 PM
Engine: 383 stroker
Transmission: th350
its been raining here lately so havnt had a chance to go out and find the problem its eather in the turn signal or one of the grounds
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
