gauges fuse blows at starting
Old Jul 12, 2007 | 06:04 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
I'm trying to find a short that is blowing the gauge fuse every time I start the engine. It won't blow in the on position but will while cranking. I've tried wiggling wires while in the run position but couldn't get the fuse to blow.
Old Jul 14, 2007 | 09:12 AM
Car: `91 rs
Engine: 352 TPI
Re: gauges fuse blows at starting
I hooked a multimeter to the fuse location and found out that during cranking its pulling the voltage down from 11.8 volts to 7.3 volts. I've got the whole dash apart right now and don't see any shorts or bare wires on any of the wires.
Old Jul 14, 2007 | 05:09 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
That's very strange.. The key applies power to the starter, it doesn't pull anything to ground, so I don't see how even a cross-short could make that happen.. It's normal for the voltage to drop somewhat but 7.3 is a bit too low for my liking.. Is the battery good and charged? Try to key it in drive and see if anything happens with the fuse then. Have there been any work done on the wiring at all?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
