tach/oil guage not working
Old Jul 14, 2007 | 09:58 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
the tach works but it not right saying 3k at idle and the oil psi guage dont work at all.what could it be?
Old Jul 14, 2007 | 10:19 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: tach/oil guage not working
The factory tachs on Camaros suffered from this problem(not sure about Firebireds).Check all the connections first.But the tach driver board failure was the most likely problem(actually resistors on the board).Best bet is to find another tach unless you can ID the bad component.Do a search as there are many threads on this topic.
On the oil pressure gauge you could have a loose or bad connection at the sending unit or the sending unit itself could be faulty.
Old Jul 14, 2007 | 10:30 PM
alpine247's Avatar
Car: 1988 IROC-Z
i forgot to search my fault. but thanks
Old Jul 18, 2007 | 09:21 AM
bcrz28's Avatar
on the oil my 91 z28 would work somewhat then 0 reading then 10, 25 then nothing. i purchased a new sending unit got underneath, checked the wires they were ok, pulled the old one out and replaced,,,,wow 30-40 psi works like new. thanks bruce
Ghettobird52
Jul 5, 2024 11:18 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Fronzizzle
Aug 17, 2015 02:52 PM
