Fuel pump not kicking in
Old Jul 22, 2007 | 04:40 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I went to work on my car and noticed the fuel pump didn't prime when I put the key in. The car won't start and I'm not getting fuel pressure. If I send 12V to the tan wire of the fuel pump relay I can hear the fuel flow (I assume that's what the noise is) and my Fuel Pressure shoots up to about 55psi.
I'm getting 12V to the Orange power wire, black is continuous to ground, and I get no voltage at red or dark green. Is there a common tie that I must have missed? How do I test those two wires (when are they hot)?
Old Jul 23, 2007 | 01:45 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel pump not kicking in
The red wire comes from the ALDL connector where you can jumper the fuel pump. Don't worry about it right now.
But put a test light on the green/wh wire and turn the key on - you should see it light up for 2 seconds (fuel prime). That's the wire from the ECM to control the Fuel Pump relay.
If the light lights up, the signal from the ECM is good and your problem is most likely the relay or connector.
If the light doesn't do anything, you might have a problem in the wiring from the ECM to the relay. (or you don't have a good ground on the light - happens often ).
Hope this helps.
Lou
Old Jul 24, 2007 | 10:42 PM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
i've got an 89 that seems to be suffering the same problem. along with the fuel pump my injectors are not pulsing, or the computer is not grounding them out. anyway let me know if you track down your problem.
Old Jul 25, 2007 | 09:17 AM
BigBadLou's Avatar
Engine: TPI
I think it's time I create a few write-ups on troubleshooting of the standard problems such as no fuel, no spark, no injectors ... I smell a tech article coming.
Lou
Old Jul 25, 2007 | 12:29 PM
agreed. i have spark though. i have the msd 6al ignition box and accel coil and im getting a tach signal on the gauge and at the ecm. i dont know if the msd would make that happen, but no fuel and no injector pulse... i was reading about a fella that had similar problems, and he just had a bad body ground, and the problem was resolved with a new negative battery cable to the body. thought i'd give it a shot as well, i've been chasing electrical issues for too long to doubt anything.
Old Aug 4, 2007 | 07:26 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
swap the relays for the fule pump and the a/c... i had the same problem on mine and it was just a shorted relay.
Old Aug 4, 2007 | 09:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
look for 20 amp fuse located on right hand side of car, it is an inline fuse and controls the ecm and fuel pump relay.
Old Aug 4, 2007 | 09:30 PM
Car: 86 T/A
Engine: HSR 355
The 20A fuse is good and power is getting to the relay. I replaced the wiring to the relay and it works, not sure if that was the problem but we'll see if it acts up again.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
