speedo issues
Old Aug 1, 2007 | 11:43 AM
stoned_pimp420's Avatar
Car: 1990 Buick Century (pimped out
Engine: 3300
Transmission: 4 spd auto
Axle/Gears: ??????????
speedo issues
When I first put the car on the road after putting in the engine and all it worked fine up until a few days ago here goes, The speedometer nor odometer work under 30 or 45 MPH depending on what it wants to do and then once it reaches it's speed it jumps from zero to however fast I'm moving, if I slow down under 35 or 40 and sometimes 30 MPH it drops straight to zero again, lets say I'm going 35 through town the needle just bounces from 0 to 35 and back and fourth until I slow down slower or speed up. Luckily it's steady at 55 and so on.
Oh yeah 1992 RS 3.1 V6 700R4 trans and some limited slip rear.
Old Aug 3, 2007 | 10:48 PM
Engine: 3300
Re: speedo issues
no ideas yet.............ANYONE please!
Old Aug 4, 2007 | 10:15 PM
Engine: 3300
Re: speedo issues
your kidding me right! so this site ( the LARGEST 3rd gen infobase in existence) has no info on a F-in speedometer in a 92 Rally Sport Camaro
Please tell me this is some sick joke that will end soon, I've gotten 2 tickets in it already for speeding before the overheating issue started taking over and I would probably have more if I could drive it more than 3 miles at a time.
I miss my RS I'M almost asking for pity here. (or a gallon of gas to torch it)
Old Aug 5, 2007 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo issues
Sorry, I don't really have any experience with electronic speedos, but I'd guess that either the speedo head or the VSS is culprit. A search would probably provide more direct info about your problem.
JamesC
Old Aug 5, 2007 | 08:39 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: speedo issues
If this were a cable driven speedo, I would look at the cabling connections that attach to the worm gear on the Trans or the back of the Speedo Unit itself.. I did run into a problem on where the cable was being pinched and it would cause very similar results.
Next thing I would check is the VSS to see if it is in good working order.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
