weird brake light issue
Old Jul 29, 2007 | 09:02 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
on my 86 firebird, I went and replaced all the bulbs and bought 2 new tailights cause the others were cracked.
now with the headlights/parking lights off, both brake bulbs on both side come on, but one isnt as bright as the other(all new bulbs) what can cause this?
Also at night when the headlights are on, when I step on the brakes the 2 inside bulbs that only light up when the headlights are on, go off and the brake lights illuminate?
what would do this?
Old Jul 30, 2007 | 06:36 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: weird brake light issue
Check the wiring to the one that isn't as bright sounds like the wires for the brake light and tail lights are swapped.
Old Jul 30, 2007 | 09:29 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
sounds like a bad ground.
Old Jul 31, 2007 | 12:36 AM
Car: 1986 firebird
thats what im thinking too.
Well me and my wiring diagram got some work to do tomorrow.
Old Aug 1, 2007 | 02:48 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
If you find that your ground wires are intact and you have not corrected your problems, check the placement of your bulbs. It's possible to put your bulbs in backwards. If that is the case, you will get voltage feedback, causing the kind of problems you are describing. This is because the contacts on the bottom of the bulbs do not align correctly with the contacts in the sockets.
Old Aug 1, 2007 | 09:40 AM
Car: 1986 firebird
I found the problem guys The black ground wire that goes to the back cover where the trunk lid contacts the metal plate up there, the wire was unhooked so it never made contact.
Now all the lights work good, as does my brake light on the rear window.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
