Charging Problems.... Need Help
Old Jul 30, 2007 | 08:04 PM
atomicskr's Avatar
I have an '86 IROC that isn't charging. I've got battery voltage at the red and black wires in the plug at the alternator but I'm not reading anything on the brown wire (all with the key on engine off). When i start the car I get batt voltage only at the output post of the generator. I had the alternator bench tested by advance auto parts and they said it was ok (normally I wouldn't believe them, but without power at the brown wire I gave them the benefit of the doubt). I've already checked all my fuses, all were good. Where should I go from here? Also... could I use a paper clip to jump the black and brown wires on the alternator? I've read something about a resistor in line on the brown wire... how much trouble could I get in by doing this?
Old Jul 31, 2007 | 09:46 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Charging Problems.... Need Help
You won't damage anything using a paper clip even if there was a resistor wire originally. If you want to make absolutely sure nothing blows up, you can use a brake/ turn/ main lamp instead of the paper clip. That'll limit the current to safe levels even if there's a short in the generator.
Old Jul 31, 2007 | 11:18 AM
atomicskr's Avatar
Well.... here's my outcome. I rechecked all the wiring today. Turns out I had power on the wire that's supposed to have the resistor (brown wire), I had power on the thicker batt wire (black/red one in the plug), but no power on the black wire. So i started tracing the black wire. Turns out it was never hooked to anything. So I jumped battery power to that wire and started the car. The alternator was still not charging. Replaced the alterntor and now it works like a champ! Got 14.2 at the back of the alternator and 13.8 at the batteries (They had gotten run down during the whole process). Anyone have any idea why GM would incorporate and unneccessary wire or what that wire might do?
Old Sep 4, 2007 | 08:34 PM
jstuart83's Avatar
where did the black wire go to
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
