Wiring heater box to orig. AC car...
Old Aug 2, 2007 | 02:30 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have my heater box bolted up. I've got 3 wires coming from it, a blue, orange, and yellow. On my car I have a whole load of wires to choose from including a relay and 2 or 3 connectors. What can I eliminate and what 3 wires do I need for my heater box? And do I still need this relay?
Old Aug 3, 2007 | 08:32 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: Wiring heater box to orig. AC car...
Take a look at this thread in the Cooling board. It has the wiring diagram for the blower motor. You can also visit this link and scroll down the page to Fig. 57 and take that link. Note that the blower motor wiring is the same as the diagram in the referenced thread.
https://www.thirdgen.org/forums/cool...s-blk-ppl.html
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Yes you need the realy. The blower motor current draw in the "HIGH" speed switch position exceed the current rating of the switch contacts. So the realy bypasses the switch for powering the motor in that speed. Note also that for HIGH speed the blower motor is connected directly to the battery, via a fusable link.
Good Luck getting everything connected....
Dave
Old Aug 5, 2007 | 11:02 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Okay, so I'm assuming by "high" your talking about the highest of the three settings available with the heater only box? Because the AC blower had 4 speeds plus a MAX, so basically 5.
So I'm going to be taking the wire that has power with my fan level switch at 3:00 (highest setting) and sending it to the relay, which will be giving power to the blower motor.
Old Aug 6, 2007 | 02:07 AM
Well, if I understand you correctly, you have a car with AC in it. You removed the AC and installed a heater only box in the engine compartment. You left the AC/Heater controls in the dash the same.
As such, you are mixing two different systems into one system. So I am not clear on where the Orange, Blue and Yellow wires from the heater box are actually connected at the box. Do all three go to the resistor, with the Orange also going to the blower motor? ( The AC sytem has four connections to the resistor, Yellow ...low speed, Tan ....M1 speed, Blue....M2 speed, Purple all speeds from resistor to the blower motor.)
Can you post a connecgtion diagram for the wires on the heater box yo installed? Then I will see if I can figure out how to connect it to the wiring to the AC/ heater controls.
Dave
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Casey Meyers
Mar 2, 2016 10:46 AM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
