Speedo Problem
Old Aug 6, 2007 | 02:17 PM
atomicskr's Avatar
Speedo Problem
Hey guys.... not sure if this is the right section for this, but here goes: recently got an '86 IROC. It has a 350 tpi and a t5 (I know it's not an original combo) and 3.23 gear in the rear ( I know because I did the spin the tires and count how many times the drive shaft spins). My problem is that my speedo is consistently 5-10 mph faster than my road speed. Could that T5 have come from a car with 3.42 gears? What can I do to rememdy this situation?
Old Aug 6, 2007 | 03:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Problem
Yes. Check to see what driven gear you have in the tranny. IIRC, 3.23's require a brown 18-tooth gear (the 3.42's, a 19-tooth white) .
JamesC
Old Aug 6, 2007 | 03:31 PM
atomicskr's Avatar
Re: Speedo Problem
Do I just unscrew the cable from the trans and pull it out or is there a clip holding it? How hard is that gear to replace?
Old Aug 6, 2007 | 03:42 PM
JamesC's Avatar
Re: Speedo Problem
Yes, unscrew the cable from the tranny. The driven gear and its sleeve are held in place by a small bolt and plate. You should be able to wiggle the gear free. Following is a link that will provide more info and some pics:
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Aug 6, 2007 | 04:18 PM
atomicskr's Avatar
Re: Speedo Problem
Thanks so much!
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
