oil pressure sender
Old Aug 4, 2007 | 06:38 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
oil pressure sender
were would the oil pressure sender be on an 87 gta with a tpi engine. i cant get my oil pressure gauge to work i carbed the motor and pulled out the computer wiring. was the plug for the oil pressure sender in the tpi wiring harness? what should i do?? i'm thinking of taking the brown wire that comes off the gauge and putting that to a single (1 wire ) oil pressue sender any thoughts??
Old Aug 4, 2007 | 10:45 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Re: oil pressure sender
I assume that the setup on you '87 would be the same as my '86 and if it is, the oil pressure sender is/was located behind the intake by the distributor. There's an L shaped unit that was threaded into the back of the intake and a connector on the top of the unit as well as the side of the unit.
Since you changed out the intake to go to a carb then you don't currently have an oil pressure sending unit. You'll need to get one designed for a carbed engine. I don't imagine you care about keeping things stock since you changed to a carb so I would recommend installing a mechanical oil pressure gauge since they are more accurate than an electric gauge.
Old Aug 6, 2007 | 11:23 PM
Axle/Gears: YEP
thanks for the reply i do care about thins looking stock (interior exterior) just a carbed motor. i went and got a oil pressure switch for that year car yesterday itlooks like the old one on my 79 t/a one wire hook up ground to block. i put that in the spot were the sender by the oil filter was and ran a wire to the gauge. all is good now. just need to figure out my charging now. thanks for answering my queastion
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
