Manual To Power Windows?
Old Aug 4, 2007 | 12:36 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, I really want to convert my manual windows to power windows but do not know what parts I will need. Can I just put a power motor in and wire it up with the switch and stuff or do I need to replace the track or something else? Thanks
Old Aug 4, 2007 | 05:12 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: Manual To Power Windows?
Years ago, I had to replace the passenger door on an 83 T/A with power windows. Used a Camaro door the same year model, except with manual windows. We installed the motor and regulator and wiring out of the original door, and it all fit and worked fine. If my memory is correct, the door had mounting holes for both manual and power window regulators, but we had to drill a hole for the wiring to pass from the door to the door post. We drilled a pilot hole, and used a knock-out tool to cut out the correct size hole for the wire loom to pass through. Best to buy a kit, or find a good donor car with everything intact. A total conversion will be a big job! Good Luck, Charles
Old Aug 4, 2007 | 07:17 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
http://www.p71interceptor.com/thirdgen/powerwindows/
Old Aug 4, 2007 | 11:03 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thanks for all the info, thats what I needed to know
Old Aug 4, 2007 | 11:08 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I think it would be easier to swap the entire doors, which is what I'm preparing to do now.
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
I have used the company below for both keyless entry & power windos on my bird. Not that expensive and everything works.
http://www.a1electric.com/Merchant2/...ct_Code=GM70-K
Corky
Old Feb 26, 2012 | 06:25 PM
letsdothi5's Avatar
Car: 91 camaro rs
did u have manual before? and did u need wireing harnees or was it in the door already
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
