No park lights need help.
Old Feb 26, 2012 | 11:15 PM
VandykeT/A's Avatar
When I first bought my camaro I had dash lights and park lights but I had one blown bulb on the pass front for the turn signal. When you turn the signal on the bulb in the dash would stay light up. The driver side worked perfect. Also if you had the dash light dimmer set anywhere other than full bright the dash lights didn't work. When I replaced the bulb in the pass side today I left the park lights on and the bulb pulled apart so i popped it out with pliers. After realizing I didn't have park lights I thought I blew a fuse but I didn't. All fuses look good. Is it possible its the headlight switch. The brake lights work perfect just no park lights and the pass turn signal doesn't flash. both front and back signals light up but won't blink. Thanks
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
