Headlight Problems 1989 Camaro
Old Feb 26, 2012 | 11:44 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I have a 1989 Camaro that I am rebuilding. I did buy a set of 4 of the sealed beam conversion lights. I have none of my old bulbs to test the system. Here is what happens,
Turn on headlights, Low Beam. All 4 lights come on, outside very bright, insides very dim.
High beam. This reverses. Low goes very dim. Is there a difference on these bulbs, as to my originals?
This headlight harness did work correctly in my car when I had it running before. The headlight switch in the car has been changed, and I am not sure of it working correctly.
If there is a adapter harness I need to make this work, Has anyone done it at home, rather then buying one? I have relays etc laying around. Thank you in advance for your help. I did search, but could not find this exact problem.
Old Feb 27, 2012 | 12:05 AM
89rsvert's Avatar
Re: Headlight Problems 1989 Camaro
Think I found a thread that shows a adapter to flip flop the ground and low beam. I should have looked a little harder before posting.
92camaroJoe
Jul 29, 2023 07:57 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
