Major help needed.
Major help needed.
i need some wiring help. i got a list of things that dont work and maybe one of you could help me figure it out. wiring is not my thing.
The power door looks dont work but the soleniod is good and the switches are good.
The power mirrors dont work but the switch is good
The cabin light does not work even with new bulb. the hatch open does not work with new switch.
any ideas???
any ideas???
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Re: Major help needed.
Other than the obvious which would be checking all the fuses in the fuse panel (and hopefully you've done that), the only thing I have any suggestions on is the door locks. Behind the drivers side kick panel there's a door lock relay that could be bad. If I recall correctly from when I installed my keyless entry, there's a small light blue wire, a small black wire, a larger black wire, and a large red (or maybe yellow) power wire coming off the relay. There may be 5 wires but those are the 4 I can remember. Check that relay, it could be bad.
sjorgens
Oct 1, 2015 07:54 PM
efiguy
Sep 27, 2015 01:30 PM
