What is that black box?
Old Aug 13, 2007 | 09:50 PM
yogi428's Avatar
Car: 87 gta convertible
Transmission: auto
Axle/Gears: 3:27
I have an 87 gta with tpi and a standard dash. What is the black box between the power brake booster and the wiper motor mounted to the firewall? It has alot of wires coming out of it. One of the wires broke and I didn't notice anything different when I drive. I connected the wire and still didn't notice anything different. What is it? Thanks for your help. yogi428
Old Aug 13, 2007 | 10:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: What is that black box?
Tiz be your headlight (door) relay module. Part of what makes your lights pop-up/down when you turn them on.
Old Aug 14, 2007 | 08:06 PM
yogi428's Avatar
Transmission: auto
Axle/Gears: 3:27
That makes sense, I haven't used my headlights for a while so I wouldn't have notice if the doors didn't work. Someone today tried to tell me the box was the pulse control module for the wipers. I noticed the broken wire when I was under the hood checking my fuel pressure. The car seems hesitate when taking off from a stop. The rest of the time it seems to run fine. The pressure guage says 42 pounds of fuel pressure at idle.
Old Aug 15, 2007 | 07:45 PM
deadbird's Avatar
Engine: TPI 305/ v6
Delay for the wipers is built into the motor/transmission assy.
42 seems a bit high for a stock fuel pressure. Stock for 87 should be around 37-39 at idle. The extra FP doesn't hurt anything. The FP should rise (and drop sharply) if you snap the throttle (no load) or raise if you're driving. If it's constant, you may have a vac. leak at the regulator.
Adding or removing the vac. line to the regulator should change the FP readings if all is well. The rise in pressure is similar to a carbs accelerator pump (adds extra gas when the throttle is opened).
Just guessing though....
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
MantyZ28
Jan 18, 2016 08:30 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
zayne0
Aug 24, 2015 07:22 PM
