distributor wiring/ECM
Old Aug 15, 2007 | 04:59 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
puttin in a 350 with a non cc carb and wondering what I need to wire for my new dist. will the old wires work (i need 12v power) or does the ecm play with the timing depending on what it is reading? because I want to disconnect the Ecm all together. are there any other issues I will have with disconnecting the ecm? thanks
Old Aug 15, 2007 | 07:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: distributor wiring/ECM
You just need the power wire to the coil for a non-cc dist.
Aside from a wiring mess to remove, the ECM does nothing but control engine/emission functions
Old Aug 15, 2007 | 08:05 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
i'm learning as i go, so the power wires for the original dist? thanks for the help
Old Aug 15, 2007 | 09:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
Yes, what originally powered the (assumption) divorced (seperate) coil (since you didn't specify the year) will power the coil. Will be the same if you had the 85-older single (coil-in-cap) HEI as well.
Old Aug 15, 2007 | 09:52 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
yeah, sorry it's a 82 TA, so it was a HEI correct, ok, I think that wire is a black and green. thanks
Old Aug 15, 2007 | 10:26 PM
deadbird's Avatar
Engine: TPI 305/ v6
Your coil wire (primary, switched +12v from ignition switch) is a 14ga pink wire.
Since you have an 82, there should be that wire (pink) with a plug on it along with a white (tach lead, seperate from the pink) that goes to the dist. These should plug right back into your non-CC dist.
Anything black is 99% of the time a ground. Green, could be a couple of things. One, temp sender to gauge wire or, A/C clutch. Something else I'm forggeting may be in there as well. Those are two that come to mind offhand though.
A.C should be on a 2 plug harness though. Gauge is one wire.
Old Aug 16, 2007 | 12:45 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
great, thanks for the details, after you said ac clutch, now I remember that's what that plug went to. one more question, my ECM do I just disconncet the wire harness from it or take the fuse out in the fuse panel? thanks again
Old Aug 17, 2007 | 05:33 PM
deadbird's Avatar
Engine: TPI 305/ v6
It won't make any difference weather you remove power from it or not. If you really want it disconnected, pul the ECM down from the pass side dash, unplug it and s--tcan it .
Or, just pulling the fuse will work, too.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
