car chooses to start
Old Aug 18, 2007 | 12:58 PM
aperfectcircle's Avatar
Car: 91 Camaro
Transmission: 700 r4
Axle/Gears: stock, soon to change.
hey guys... i just started having this problem, my car wouldnt start so i figured it was my starter, to my disliking it still didnt not want to start. it acts like it doesent want to do anything it has all power and everything but no juice to the starter. and if i leave it for a few minutes it acts like all is well and starts the car.. someone told me about an intermittent starter relay could this be the problem??
Old Aug 20, 2007 | 04:10 PM
camaro91boy's Avatar
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
Re: car chooses to start
yours to huh mine will only start if i get a jumpstart from a running car. it just decides to start when ever usually dosen't want to start at the most inconveniant times. if your problem is not as the same as mine check your nuetral safety switch i figured this out when i got mad and slammed the shifter forward and then it started.
Old Aug 21, 2007 | 07:55 PM
pogmaster's Avatar
Car: 91 Firebird Formula
Engine: HSR 350 Sportsman IIs 210/220
Axle/Gears: 3.23 stock 10 bolt
its possessed! i have the same problem and its getting to me! i've replaced my ignition switch, neutral safety switch or w/e, and the relay at the drivers foot.... still no good. i randomly get power to the starter... maybe a bad connection somewheres??? im tired of throwin parts at it
Old Aug 22, 2007 | 02:23 PM
i just fixed mine last night check all of the wires leading off of the battery and check the battery. my battery was cracked right at the pos. connection and leaked bat acid all over cable so i replaced all of the connectors and put in one of my 800 cold crank batteries that i had been charging for a long time now. it has yet to give me a problem. let me know how this works for you.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
killer777
Aug 8, 2015 02:47 PM
