Electrical Nightmare
Old Aug 22, 2007 | 11:30 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
In advance sorry for the long post, Anyway Whoever did the engine swap on my car before I bought it srewed up the wiring. When I step on the brake pedal my parking lights come on. And when I select to have only my parking lights on my brake lights are on even though my foot is not on the brake pedal. Also My coolant temp guage does not work. It will move around sometimes but it stays in one spot like at 110 even though the scan tool says its 220 degrees. My fuel guage doesn't work either. Its pegged past the full mark and will not move.
Old Aug 24, 2007 | 12:06 AM
Beast407's Avatar
Re: Electrical Nightmare
Check the bulbs installed in the brake lights. They should be two-filament bulbs. If single filament bulbs are installed it will jump the brake and parking lights as you are describing.
Also, your fuel gauge problem is due to an open in the sending circuit.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
327IROC85
Sep 23, 2015 12:11 AM
