Automatic up/down switches
Old Aug 26, 2007 | 03:45 PM
pgslunchbox's Avatar
Car: '91 G92 Z28
Engine: TPI 355
Transmission: B/W 5 speed
Automatic window switches do they have like a built in relay that tells them when to kicks off is it somewhere in the wiring?
Old Aug 26, 2007 | 05:45 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Re: Automatic up/down switches
I'm not sure what your question is. I had auto-up/down added to my 92's windows when the Viper 791XV remote start/security was installed. You need the DEI 530T window module, I believe it is just wired into the window switch wires. They're on eBay for $60 or less and not hard to put in from what I understand, but I haven't installed one myself.
Old Aug 26, 2007 | 06:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.radiomancaraudio.com/deta...DUCT_ID=DE530T
JamesC
Old Aug 26, 2007 | 08:21 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Yup, the module does auto up / down... it has inputs for alarm to go up with alarm arm / vent / open and also ads the feature of tap / release and it opens or closes all the way... also stops if it meets resistance, i.e. buddy's head in the window
Raf
Old Aug 27, 2007 | 01:31 PM
Car: '91 G92 Z28
Engine: TPI 355
What JamesC posted up was pretty much exactly what I was looking for. Thanx.
Old Aug 27, 2007 | 01:39 PM
Car: '91 G92 Z28
Engine: TPI 355
Can that module be wired in to be activated off a keyless entry setup something like autoloc or is it made to go with their alarm systems?
Old Aug 27, 2007 | 01:49 PM
luvofjah's Avatar
Usually it has a pulsed input (example, ground for a second) that tell is to close.... another channel tap will vent the windows, and that same output (from an alarm will open it)...
Your keyless entry my be able to find a wire that will make it close the windows, but could be tricky... Check the DEI site and you should be able to download the instructions / inputs...
Raf
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
luvofjah
Sep 3, 2015 07:08 PM
