All lights flicker, Ground problem maybe~Help~
Old Aug 27, 2007 | 01:30 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello, When i bought my new camaro a week ago , he told me that when they swapped out the old 305 for the new 350 the ground wasn't hooked up properly somewhere?. But when the car is running all the lights flicker, from the headlights to the dome lights, every now and then it will stay on with no flicking for a few seconds then go back. Just wanted to know what i can do to track down the problem or what should i do to fix it. Theres a brand new optimum battery so i know its not that and the battery meter is aways full so its not draining but it does flicker as well.
Old Sep 2, 2007 | 08:21 AM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Re: All lights flicker, Ground problem maybe~Help~
I have the same problem after my motor swap. Check to see if you have the ground strap from the back of the passenger head to the firewall as well as other grounds. The one on the passenger head should look like a flat silver type of wire. I'm missing it but I just tried using a neg battery cable and ran it from the driver side cylinder head to a strut tower bolt to see if grounding it would work but that made no difference. Maybe doing that won't work but I thought it should if that was the problem. Anyone have any ideas? I still think it's a ground issue but could it be the voltage regulator in the alternator?
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
