Car Killing security light turns on
Old Aug 28, 2007 | 12:36 AM
Hellfirebird's Avatar
Car: 91 Firebird
Engine: 5.0 TPI
Transmission: Stock B&M shift kit
I have been driving down the street and at strange times my car will simply kill and the s3ecurity light will go on. I can put it in park and try to start it up and sometimes it works and sometimes I have to wait for a while. Is it a problem with the key? It seems to happen more often when I have my radio on and my subs are going. What needs to be replaced?
Old Aug 28, 2007 | 09:10 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Car Killing security light turns on
That could be a problem with the key contacts in your ignition cylinder. You should narrow it down though before you start replacing expensive parts.
If you wiggle the key in the ignition cylinder and the car starts, it's most likely the cylinder. If not, it could be wires under the dash. But don't worry, the wires are not usually good.
Lou
Ghettobird52
Jul 5, 2024 11:18 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
