Pulldown Motor and Brake Light
Old Sep 10, 2007 | 08:48 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, my pull down motor runs constantly when it is plugged in, but it doesn't go up or down. The motor is good, but the pull down unit doesn't move. Is there any fixable reason for this?
Also, how does the third brake light in the spoiler get wired in? Is there some kind of contact plate or something like that?
Old Sep 12, 2007 | 11:45 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Pulldown Motor and Brake Light
Pull-down runs all the time, yet doesn't go up or down = bad gear nut. I sell it as TDS 109111 ($7) or you can get it from the dealer. The 1986-90 HMSL is powered by a spring-loaded contact and mating contact pad just to the left of the pull-down motor (as you are facing it from the rear of the car). I'm not sure how your 1985 hatch glass mounted HMSL is wired. It is likely hard-wired as the 1991-92 coupes HMSL are.
Lon Salgren
Top-Down Solutions
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
