Shaved Door Handle Button
Old Sep 29, 2007 | 07:06 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I need to rewire my shave door handle button. The original owner stuck the power wire for the solinoid into the fuse box.Litteraly the wire is stuck into one of the fuses. Also the button is on the left rear inner wheel well. The original owner ran the wire from the fuse box under the carpet, drilled a hole through the side of the car to the wheel well. Whats the best way to power the soliniod.
Old Sep 29, 2007 | 08:20 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: Shaved Door Handle Button
That is just straight up ghetto dude..... What you should do is look at a wiring diagram for a nitrous kit or something and use a relay. it is alot smarter to use one.... and if I were you, I would try hiding that button a little better than that..... like inside the fenderwell....
Old Sep 30, 2007 | 01:50 PM
I was thinking to use the wiper blade arm as a contact point switch to when you pressed down on the arm the switch would close opening the door. I also plan on eventualy getting a shaved door handle kit that comes with transponders to open the door.
Old Sep 30, 2007 | 08:18 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Hide a magnetic reed switch in one of the side-view mirrors. Trigger it with a laptop voice coil magnet on your keychain...
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
sahlomonic
Sep 20, 2015 07:15 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
