fuel gauge reads 1/4 after........
Old Oct 1, 2007 | 04:57 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
fuel gauge read full after a fill up. Then after approx 50 miles of driving it will STAY at 1/4 of a tank. Car is running rich and I get approx 240mi a tank. 5.7tbi swap. (i had the tbi5.0).
New guage cluster? run separte fuel gauge?
help a newbie out .
thanks guys
Old Nov 22, 2007 | 10:31 PM
gkrynick22's Avatar
Car: 1985 Corvette/Searching For F-body
Engine: 350 TPI/????
Transmission: 4+3 Manual/????
Axle/Gears: 3.23/????
Re: fuel gauge reads 1/4 after........
Sound to me like a fuel sending unit. Usually when the fuel sending unit goes bad the fuel guage reads wrong. Hope this helps(if I am right)
Old Nov 23, 2007 | 11:21 PM
1991ON20's's Avatar
fuel sending unit inside the tank? or is it something i can change on the outside of the tank?
thanks
Old Nov 24, 2007 | 12:07 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
not too sure about these cars, but the sending unit is usually part of the fuel pump assy that pulls out the top of the tank. Most people on this site access that by cutting a hole in the floor under the carpet where the t-tops are stored. Not too sure if I would do that, but since it is a really indepth job I would at least consider it.
Old Nov 28, 2007 | 07:28 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I would disagree, I think "most" people on this sight would not cut an access panel. I think "most" people on this sight would do it the right way and drop the tank.
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
